 Post subject: weather for two places
PostPosted: January 6th, 2014, 2:42 pm
is it possible to have in the same widget the weather results of two or more places? i had an idea to make a widget and looks like that... backgroung a map of my town and there will be the weather conditions of many different areas of my town or my country bur for this is needed the same widget to take data from many areas...
PostPosted: January 6th, 2014, 3:32 pm
Try to use more than one weathercores in your widget and assign a different core for every city. I made world clock and multi-pic widget with this "trick" and worked. I never used this for a weather widget, but you can try..
PostPosted: January 7th, 2014, 12:12 am
I can confirm that way is working and I am using this method for a very long time.
PostPosted: January 7th, 2014, 1:20 pm
ok i made it thanks ..it was easy finally... but i use another widget and make some adjustments cloned some things and put new elements that i wanted...
if you want to see what i did i sent the widget...ok is my first attemp and wants works...and its about my country..everyone who wants to make for him town can go to google maps and screen the area , then edit the image backgroun , move the text and load the widget..then go to seach city and make suitable changes
new_maps_weather.XWidgetPkg [1.19 MiB]
Downloaded 372 times
