PostPosted: December 9th, 2013, 3:10 pm
can somebody give me a code for change image with percent
the example like if ram make higher the progress bar on xwidget will change the colour from green to red
anybody can help me ?
i want port this rainmeter widget for xwidget
(sorry for my bad english)
PostPosted: December 9th, 2013, 5:03 pm
You can use the default "Gradient option" of the Designer or create a .png image and then apply it like the "Foreground Fill" for the progress bar choosing "fill with graphic"- "Allow clipped". You can find all these in the designer. Just play with the options to see the results..
PostPosted: December 9th, 2013, 6:02 pm
oke, i will try, thanks for helping
EDIT:
but i need to change it with 3 colour
green - yellow - red
and what u say just for 1 colour, i need how it be change in percent
PostPosted: December 9th, 2013, 6:25 pm
EDIT:
When you use the gradient option is not for one colour! Set the start colour "green" and the end colour "red" and you will see..
Also as I said you can use a ready png image and use it for the "Foreground Fill" of the progress bar, like this one for example:
PostPosted: December 9th, 2013, 6:32 pm
jimking wrote:
EDIT:
but not like that, what i mean is full green, when 60% the image will be yellow, if 30% that will be red
PostPosted: December 9th, 2013, 6:41 pm
Then you should make the image by yourself dexterkamiya and use the %tenth code! All who made a widgets like this use custom images..
Like this one:
http://android.xwidget.com/page/widgets ... ontal.html
or
use the "when the % is .... show this" script like this one:
viewtopic.php?f=11&t=3036&hilit=lights
PostPosted: December 9th, 2013, 10:31 pm
Like this one:
or
thanks, its work now :D
thanks for helping
ScreenShoot
PostPosted: December 10th, 2013, 9:52 am
as an another way:
you could also use this in your code:
progressbar1.Fore.Draw.SolidColor.Color=rgba(241,117,0,255)
and use your color inside rgba()
for example:
rgba(241,117,0,255) //for orange color
rgba(19,228,0,255) //for green color
rgba(226,0,0,255) //for red color
you can get color numbers from one of the select color dialogs in designer
by using this method
the code will be like this:
function cpucore1OnUpdate(Sender)
  if(cpucore1.get("%Percent")<50)
     progressbar1.Fore.Draw.SolidColor.Color=rgba(19,228,0,255)
  else if(cpucore1.get("%Percent")>=50&cpucore1.get("%Percent")<80)
  else if(cpucore1.get("%Percent")>=80)
     progressbar1.Fore.Draw.SolidColor.Color=rgba(226,0,0,255)
