Post new topic Reply to topic  [ 25 posts ]
PostPosted: December 8th, 2013, 3:34 am
hello..is there any email widget which sounds when a new email has been sent? and if it is possible if there could be more than one email account...i have email to yahoo and gmail..ok i could run the same widget twice but i am interest for a widget with this function....now at the moment i use a widget called "three e-mails" and i am satisfied ..can i make it to sound every mail arrives?
Last edited by tasmani2606 on December 13th, 2013, 12:16 am, edited 1 time in total.
PostPosted: December 12th, 2013, 10:53 am
tasmani2606 wrote:
hello..is there any email widget which sounds when a new email has been sent? and if it is possible if tere could be more than one email...i have email to yahoo ang gmail..ok i could run the same widget twice but i am intrest for a widget with this function....now at the moment i use a widget called "three e-mails" and i am satisfied ..can i make it to sound every mail arrive?
send me your widget, maybe i can add this function to it
PostPosted: December 12th, 2013, 11:52 am
As I understand hamid he doesn't have any widget. He asks if there is any widget with this function or to create one..! :mrgreen:
PostPosted: December 12th, 2013, 4:29 pm
i understand from this that he has a widget for it and its name is "three e-mails";
so i asked him to send it.
am i wrong? :!:
PostPosted: December 13th, 2013, 12:13 am
http://tchiro.deviantart.com/art/Three- ... -295770133
PostPosted: December 15th, 2013, 2:47 am
tasmani2606 wrote:
http://tchiro.deviantart.com/art/Three-E-mail-XWidget-295770133
the only thing that available in the core is "%Count"
So the only way you get the notification is when:
>count of emails changes (more or less)
>count of emails increases (only more)
i added both of them to decide yourself
also added some other types of notification:
>ColorEffect
>TrayBaloon
>Sound
>ConfirmBox
you can change them through right click menu
also you can change the "sound.wav" in the widget folder with your own wav file with the same name
i have changed most of the parts in widget
hope this would be useful
i don't have any emails available right now to test it
but it should work ok.
if there is any problem, just report it here, and i'll check it out.
three_e-mail_with_notification.xwp [412.08 KiB]
Downloaded 619 times
PostPosted: December 15th, 2013, 5:46 am
you are great...it is exactly what i wanted..thanks a lot
PostPosted: December 15th, 2013, 12:38 pm
i was harry to say it's ok... there has been a problem... the widget is ok and more than ok is as i said exactly what i want beacause i tried it to gmail and i was pleased but i noticed that the second email at yahoo was not loaded...i use other widget and the same result...i went to previous versio of xwidget the same... there didn't write how many emails i have to my mailbox of yahoo...i went to account settings but i hadn't changed anything so i think i didn't do anything bad...
PostPosted: December 15th, 2013, 3:25 pm
this shouldn't be a problem with widget:
i have used same core of original widget,
so if it works for yahoo then this should work too.
problem should be one of these:
1. it might be a problem with xwidget core, maybe it doesn't support yahoo right now.
>could you use yahoo before in xwidget?
or
2. it might be a temporary problem with yahoo servers
>can you open your yahoo mail with browser?
or
3. you didn't configure it properly
>i have never used programs to check mails so i couldn't help you so much in configuration
if it is a configuration problem just i can recommend these to try:
1. in the settings Dialog for each of the mails there are two listboxs:
>First(Top) > [POP3 Server name]: for setting Server that should get emails from (this is important)
>>Second(Bottom) > [mail client or URL]: for setting url of mailServer to open it when you request to open it in browser (this is not needed by own widget, it's just for opening browser for you)
2. [POP3 Server name] that for yahoo available by default in the list is [pop.mail.yahoo.cn] and that is [.cn] means for [china], so if you're not in china or your email is not [@yahoo.cn] maybe you should use another POP3 Server name:
>try [pop.mail.yahoo.com] or anything else specified for your country
>>Search for correct yahoo pop3 server for your country in the net
3. note that [POP3 Server name] box is not only a dropdown list,
you can add your own server name to that box too,
so if your desired server not exist in the list, type it in the box
PostPosted: December 15th, 2013, 11:15 pm
to answer to your questions...first i know it isn't problem of widget i tried it with another widget also... i could say that until 2 days ago i was receiving emails info from yahoo from xwidget... yes i can use yahoo mail from my browser... i put the same setting as the previous widget... the settings are for POP3 Server name because my mail is @yahoo.gr i put "pop.mail.yahoo.gr" and at the Mail client or URL i put "http://mail.google.gr/" my username without @yahoo.gr and not capital and password
PostPosted: December 16th, 2013, 8:00 pm
also try these:
1. "pop.mail.yahoo.com": this is the main server of yahoo, maybe it works.
2. do you try with one mail running or more?
>try only with one mail running, also make sure one email widget is running.
PostPosted: December 18th, 2013, 11:36 am
no i couldn't fix the matter...i sent email to yahoo maybe they would know something but no luck... itried many different settings no result always shows -- at the mail
PostPosted: December 18th, 2013, 11:43 am
that's the answer from yahoo
POP server settings
Want to access Yahoo Mail from an email program like Outlook or Mac Mail? Here's the settings you'll need.
Incoming Mail (POP) Server - Requires SSL
Server: pop.mail.yahoo.com
Port: 995
Requires SSL: Yes
Outgoing Mail (SMTP) Server - Requires TLS
Server: smtp.mail.yahoo.com
Port: 465 or 587
Requires SSL: Yes
Requires authentication: Yes
If your POP client doesn't offer TLS, you'll still be able to use SSL.
Login info - Requires authentication
Email address: Your full email address (name@domain.com.)
Password: Your account's password.
PostPosted: December 20th, 2013, 6:58 am
>for login setting
as you see yahoo told you to use full email address as username (username@domain.com)
but you told before that you used only username for login.
so try these first:
username@yahoo.com
username@yahoo.gr
Port: 995
Requires SSL: Yes
>for port setting:
i don't know what you should exactly do about it;
but for some applications i see that you can use port like this in urlbar: [domain.com:port]
ex: pop.mail.yahoo.com:995
but i don't know if this is supported for all applications
and also i don't know if it is supported by xwidget.
>for SSL connection:
i don't know that xwidget uses SSL for the connection or not.
PostPosted: December 20th, 2013, 11:34 pm
i give up... i have made all the possible combinations but always the same result...i will not bother anymore thank you
PostPosted: December 29th, 2013, 5:17 pm
can you add notification sound to razorgmail pls.
PostPosted: December 30th, 2013, 8:26 am
sure; if i have time;
just put the link for the widget
PostPosted: January 12th, 2014, 6:22 pm
i didn't noticed that pop3mailcore will save username and password to the theme file,
but it encoded to some other characters;
also it saves them without any confirmation in setting window or any notification
so be aware of that, and don't share your theme file with anyone else
and another thing that i didn't noticed was that it will reload previous mailboxes on restart
so i decided to make a new release:
three e-mail with notification v2 [2014.01.13]
here's the new features:
1. on restart of widget it will save and restore the email counts and last changed time
2. added green color to the progress animation to better be displayed while working
3. [bugfixed] when using same mailbox for another email Server or with another username wrong notification could be happen, because of old counts exist for another email account
>now it will reset the previous counting on username change or on email Server change
4. [bugfixed] progress animation in previous version only works for mailbox1
>now it works with all 3 mailboxes
5. some optimization to the code (most of the things in code changed)
please test it out and report if any bugs
three_e-mail_with_notification_v2.xwp [413.58 KiB]
Downloaded 561 times
PostPosted: January 14th, 2014, 11:39 am
ok man good changes.... but the problem with yahoo still remains :cry: i didn't sent my theme i sent the link from devianart
PostPosted: January 24th, 2014, 12:56 am
Here is the link for razormail
https://dl.dropboxusercontent.com/u/577 ... rgmail.xwp
PostPosted: May 20th, 2014, 4:55 pm
Hey Guys, I noticed an error in the "Email Account Settings", i think the error is in the pop3mailcore itself
cause i checked and the POP3 Server name for yahoo is "pop.mail.yahoo.com" but the "Email Account Settings" shows ".cn" at the end.
https://ph.help.yahoo.com/kb/mail/pop-s ... sions=true
don't know if that's the issue, just thought maybe its something silly like a typo.
Edit:
I tried it, but doesn't work either, nor does Hotmail, is Gmail the only one working?
-George Carlin
PostPosted: May 21st, 2014, 1:15 am
Guys the core's name is "GMail" so works ONLY for GMail! :lol:
For the rest is required a script code..
PostPosted: May 21st, 2014, 6:43 am
Edit:
yahoo.cn means yahoo for china
.cn is for chinese websites
i see that the server selection list is editable (you can type there)
maybe you can use your url there to work,
but i didn't tested it out
they're talking about pop3mailcore not gmailcore
there are 2 mail cores in xwidget:
pop3mailcore: can access gmail and some other mail servers, but have some less tags
gmailcore: can only access gmail server, but it have more tags to be used
PostPosted: June 2nd, 2014, 10:12 pm
three_e-mail_with_notification_v3 [2014.06.03]:
new Features:
[bug fixed]: color effect doesn't work on update
[bug fixed]: bad linking of objects
[Added]: default to [onCountChange] and [ColorEffect] Enabled
Edit: Attachment updated due to bad upload
three_e-mail_with_notification_v3 [2014.06.03].xwp [413.59 KiB]
Downloaded 518 times
and here's another one:
razorgmail_with_notification_v1 [2014.06.03]:
i just edited the Object names and change some objects to be compatible with my old script code,
i didn't rewrited the code, i just removed some extra things from the code
so the code should work ok with this widget
sorry to be so late
plz test it out and report the bugs here
Features:
1. Notify on:
2. types of notification (you can change them through right click menu):
>ColorEffect
>TrayBaloon
>Sound
>ConfirmBox
3. save and restore the email counts and last changed time on widget restart
4. you can change the "sound.wav" in the widget folder with your own wav file with the same name
razorgmail_with_notification_v1.1 [2014.06.03]:
[Added]: Text shadow for the mail Counter
razorgmail_with_notification_v1.1 [2014.06.03].xwp [415.21 KiB]
Downloaded 540 times
PostPosted: June 5th, 2014, 12:31 am
Mail core doesn't support SSL. GMail core works only on web feeds. You SHOULD NOT USE IT AS ALL DATA IS TRANSFERRED IN PLANTEXT!
See: viewtopic.php?f=3&t=3000
