PostPosted: November 14th, 2013, 12:13 pm
Finding this image
I had the idea to create a weather image that it will show images from the selecting city!
Of course this needs some professional script coding and that's why digigamer, known for his great capabilities with the scripts, started
to make a script for this..
We're using the "www.flickr.com" service.
digigamer made a test widget with this online function so everytime the widget will download and show an image from the selecting city.
The problem is that there is a bug and 9/10 times the image downloading doesn't work...
So any help for making this work will be great! :)
NOTE:
The API key that the widget is using is my PERSONAL key from my profile of yahoo. Please respect that and if you want to make your own widget please ask for a new key:
http://www.flickr.com/services/api/keys/
Here is the test widget to check the script:
glass_weather_jimking.xwp [1.49 MiB]
Downloaded 364 times
