PostPosted: November 10th, 2013, 4:20 pm
I want to make a widget with a multicolor function like this one:
viewtopic.php?f=11&t=3752
but using an image. Creating a white image in the Designer (background->solid color->white) is it possible to add a click on function so the user can change the color of the image with RGB..?
PostPosted: November 10th, 2013, 11:33 pm
Do you mean like this ?
function image1OnClick(Sender)
image1.Background.SolidColor.Color = SelectColor(image1.Background.SolidColor.Color);
//Note- the change will not be saved unless you save the value in the ini file and load it at startup - SetValue and getinivalue
PostPosted: November 11th, 2013, 2:35 am
Hi meme. Yes, exactly like this! :D
Thanksssss
Here is the widget that uses this function:
viewtopic.php?f=11&t=3757
PostPosted: November 11th, 2013, 4:12 pm
And in case of a text meme..??
I try this but doesn't work.. :(
function image2OnClick(Sender)
text1.Text.FontColor = SelectColor(text1.Text.FontColor);
Also when we want with this simple click on function change multiple texts having the same color we have to add:
text2...........(same)
text3..........
PostPosted: November 11th, 2013, 9:02 pm
viewtopic.php?f=10&t=3684
the attribute name is wrong
PostPosted: November 12th, 2013, 1:34 am
qiancang wrote:
http://bbs.xwidget.com/viewtopic.php?f=10&t=3684
Thanks qiancang! I didn't notice this topic...
PostPosted: November 12th, 2013, 1:43 am
I replaced the script and now works great! :) But there is a command for multi-selection? (ALL the txts will have the same color with one click)
I have these components/texts but using this script the RGB window shows for each txt separately, the user have to confirm x9 times the color...
text1.font.fill.color = selectColor(text1.font.fill.color);
text2.font.fill.color = selectColor(text1.font.fill.color);
text3.font.fill.color = selectColor(text1.font.fill.color);
text4.font.fill.color = selectColor(text1.font.fill.color);
text5.font.fill.color = selectColor(text1.font.fill.color);
text6.font.fill.color = selectColor(text1.font.fill.color);
text7.font.fill.color = selectColor(text1.font.fill.color);
text8.font.fill.color = selectColor(text1.font.fill.color);
dot2.font.fill.color = selectColor(text1.font.fill.color);
PostPosted: November 12th, 2013, 2:28 am
text2.font.fill.color = text1.font.fill.color;
PostPosted: November 12th, 2013, 2:35 am
Great! :D
It will be nice if you update the "Attributes and Functions Relevant to Color" topic with this particular, when we want to control more than one txt, so the other users can find it helpful..
Thanks again qiancang!
