 Post subject: battery icons show/hide
PostPosted: October 27th, 2013, 5:36 am
I would like to create a battery meter. I have 11 images: Image0,1,2,3.....10
Ι put the images on top of each other. Each image will be appeared only on a certain value/battery level.
Image0 -> level 0-9
Image1 -> level 10-19
Image2 -> level 20-29
Image3 -> level 30-39
Image4 -> level 40-49
Image5 -> level 50-59
Image6 -> level 60-69
Image7 -> level 70-79
Image8 -> level 80-89
Image9 -> level 90-99
Image10 -> level 100
I use this script but seems that something is missing because doesn't work...
function batterycore1OnUpdate(Sender)
var batteryvalue = parseInt(batterycore1.get("%Percent"));
if(batteryvalue<=9)
image0.visible = true
else
image1.visible = false
image2.visible = false
image3.visible = false
image4.visible = false
image5.visible = false
image6.visible = false
image7.visible = false
image8.visible = false
image9.visible = false
image10.visible = false
if(batteryvalue>=10)
image1.visible = true
else
image0.visible = false
if(batteryvalue>=20)
image2.visible = true
else
if(batteryvalue>=30)
image3.visible = true
else
if(batteryvalue>=40)
image4.visible = true
else
if(batteryvalue>=50)
image5.visible = true
else
if(batteryvalue>=60)
image6.visible = true
else
if(batteryvalue>=70)
image7.visible = true
else
if(batteryvalue>=80)
image8.visible = true
else
if(batteryvalue>=90)
image9.visible = true
else
if(batteryvalue=100)
image10.visible = true
else
Any help...? :?
PostPosted: October 27th, 2013, 12:52 pm
Try this...
if (batteryvalue<=9)
if(batteryvalue>=10 && batteryvalue<=19)
if(batteryvalue>=20 && batteryvalue<=29)
if(batteryvalue>=30 && batteryvalue<=39)
if(batteryvalue>=40 && batteryvalue<=49)
if(batteryvalue>=50 && batteryvalue<=59)
if(batteryvalue>=60 && batteryvalue<=69)
if(batteryvalue>=70 && batteryvalue<=79)
if(batteryvalue>=80 && batteryvalue<=89)
if(batteryvalue>=90 && batteryvalue<=99)
if(batteryvalue==100)
Note The method used by digigamer :idea:
//act if changed
minimizes system resources for code that is triggered frequently, like every second. :mrgreen:
PostPosted: October 27th, 2013, 2:11 pm
Thanks a lot meme works great! :D
PostPosted: October 28th, 2013, 8:32 am
Wait, you can set it's binding to batterycore's %Tenth
something like: Bindingcore Format : battery-%Tenth.png
where the images are battery-1.png,...,battery-10.png.
See this:
viewtopic.php?f=11&t=3628
