Post new topic Reply to topic  [ 30 posts ]
 Post subject: Show txt on a time ?
PostPosted: October 18th, 2013, 7:23 am
Guys I need help with it...
I would like to make this as a full screen widget. Using these two scriprts:
function widgetOnLoad()
eval(datetimecore1.get("%WeekEn")).Font.Color = rgba(41,1,214,255);
eval(datetimecore1.get("%AMPM")).Font.Color = rgba(197,16,16,255);
I finished the week days and the am/pm and are shown only in the corrisponding time with glow effect like the screenshot.
BUt how about the numbers of the hours, minutes and seconds!???
What is the script for these so I can have the same effect???
As I noticed the Designer doesn't accept the numbers as rename of the txts "01","02" etc... So what..??? :?:
 Post subject: Re: Show txt on a time ?
PostPosted: October 18th, 2013, 11:01 pm
Component names cannot be started with a number. That's true for every programming language
Name texts with a preceeding character like "num1" etc..
then eval("num"+core1.get(null,"%Hour")).Effect.Glow.Enabled = true;
:mrgreen:
PostPosted: October 19th, 2013, 1:01 am
Thanks man!!! And what about the colour of the txt? I will set it from the designer?
Edit: Never mind.. I just read your note in DA! :)
PostPosted: October 19th, 2013, 6:37 am
DG I almost finished the widget (I have to add the txts for the seconds), the appearing of the corresponding text/colours is working but the problem is doesn't update...(the next colour digit doesn't show up next..) :(
I sent you the file through a Note on DA to check what I mean..
Edit:
Using the same code for the datetimecore1OnUpdate:
function datetimecore1OnUpdate(Sender)
eval("num"+datetimecore1.get("%Hour0")).Font.Color = rgba(0,93,171,255); //hour0
eval("min"+datetimecore1.get("%Minute0")).Font.Color = rgba(0,20,171,255); //minute0
I notice that the numbers are now updated BUT the previous number remains visible.....
PostPosted: October 19th, 2013, 4:01 pm
Without changing the naming system you have used
ResetAllColors(); ---------------------------------------------------------------------- ADD this line
function ResetAllColors() // reset colors -------------------------------------------------- ADD this function
for (var m=0; m<60; m++) // count up the minutes 0-59
eval("min" + ("0" + m).slice(-2)).Font.Color = rgba(0,0,0,0); // reset all mins to transparent
for (var h=1; h<12; h++) // count up the hours 1-12
eval("num" + ("0" + h).slice(-2)).Font.Color = rgba(0,0,0,0); // reset all nums to transparent
eval(AM).Font.Color = rgba(0,0,0,0);
eval(PM).Font.Color = rgba(0,0,0,0);
eval(Monday).Font.Color = rgba(0,0,0,0);
eval(Tuesday).Font.Color = rgba(0,0,0,0);
eval(Wednesday).Font.Color = rgba(0,0,0,0);
eval(Thursday).Font.Color = rgba(0,0,0,0);
eval(Friday).Font.Color = rgba(0,0,0,0);
eval(Saturday).Font.Color = rgba(0,0,0,0);
eval(Sunday).Font.Color = rgba(0,0,0,0);
//To reduce system resources this code only need to run if the time/seconds = 0
//this could be add with an IF statement at the start of the function datetimecore1OnUpdate(Sender)
PostPosted: October 19th, 2013, 6:08 pm
Thanks meme!!! Excellent work! :D
Now works as it should, BUT damm, the cpu consumption makes the widget unusable... :(
No way to reduce it..?
This happens because of the number of the txts???
If yes, I have an idea! Is a full screen widget. So I can take a screenshot with all the numbers in black, so I can delete all the bottom txts and leave all the other that use the script code! :idea:
Edit:
I did it, I notice some improvement with the cpu but is still high.. So the code causes it..? :?
PostPosted: October 19th, 2013, 6:58 pm
if the above is done the code will run only once every minute when the seconds = 0, which is the only time you want it to update anyway.
if (eval(datetimecore1.get("%Second")) == 0) ------------------------------------------- ADD this if statement
{ ------------------------------------------- ADD this
ResetAllColors();
} -------------------------------------------- ADD this
To make it work properly on start up you need the function widgetOnLoad() to be added to WIDGET - FUNCTIONS - ONLOAD - ( currently it is not running at startup. )
Also fix a mistake I made please edit the line
for (var h=1; h<12; h++) // count up the hours 1-12 -------------------------------------------- EDIT this
it should be
for (var h=1; h<13; h++) // count up the hours 1-12
PostPosted: October 19th, 2013, 7:20 pm
Added the new script and cpu now is 0..! :D
Also the make it work properly on start up you need the function widgetOnLoad() to be added to WIDGET - FUNCTIONS - ONLOAD - ( currently it is not running at startup. )
Without it the widget will start work on the next minute right...?
What I have to add it in the space..? (I have to copy the entire code?)
PostPosted: October 19th, 2013, 7:40 pm
Please read my last edited post to correct a mistake I made.
Yes
No the code is OK as you have it, it is not being called to run at startup
to get it to run the function widgetOnLoad() at startup
Click DESIGN button in the toolbar to go to design mode
Click on WIDGET in the top left side column
Click FUNCTIONS under widget attributes, the blue box on top of the right side column
In the OnLoad edit box SELECT scripting code
it should take you to the function widgetOnLoad() you have already created.
now it will run at startup.
PostPosted: October 19th, 2013, 7:58 pm
Yes, I fixed it!
Yes, I know the path but I'm stupid because I had deleted this part in my script here and that's why I was a little confused..
But all ok now!
Tomorrow I will put the seconds adding the corrisponding lines in the script..
1000 THANKS FOR YOUR HELP, TIME AND AVAILABILITY meme! :D
You did an amazing work! And sorry if I was a "pain in the ass"! :)
As I said to digigamer, both you guys should be part of the official programming team of the XWidget!
PostPosted: October 19th, 2013, 8:47 pm
Thank you jimking for you kind words.... happy to help. :)
Not sure what you mean, but remember the update code only runs every minute at 0 seconds.
PostPosted: October 20th, 2013, 2:45 am
I made txts with name "sec", sec00, sec01.....sec59, so I have light up for the secs too and here is the full script:
ResetAllColors();
eval(datetimecore1.get("%WeekEn")).Font.Color = rgba(138,0,178,255);
eval("sec"+datetimecore1.get("%Second0")).Font.Color = rgba(84,230,0,255); //second0
for (var s=0; s<60; s++) // count up the seconds 0-59
eval("sec" + ("0" + s).slice(-2)).Font.Color = rgba(0,0,0,0); // reset all secs to transparent
WITH RED COLOUR FOR THE EXTRA/NEW CODE
Deleted the
do the job BUT the cpu once again is "Rising To The Sky"...
I'm afraid that we can't combine both right...?
PostPosted: October 20th, 2013, 3:05 am
this widget looks great!
if you can upload the widget,i think i can reduce the code and components.
PostPosted: October 20th, 2013, 4:02 am
Here qiancang: :)
I left the "if (eval(datetimecore1.get("%Second")) == 0)" code so the seconds function doesn't work..
insanity_time_full_screen(1).xwp [1.08 MiB]
Downloaded 703 times
PostPosted: October 20th, 2013, 4:45 am
how to handle the time 15:12:12? minute and second are the same, second text will cover the minute text.
PostPosted: October 20th, 2013, 5:58 am
Yes, as the original design (this is actually an Android lwp) the seconds will cover the minute txt but only for one sec when the values will be the same. That's why there are different colours for each part. At the beginning it seemed strange to me too but there is no other option I think..
The difficult part is to fix the cpu consumption with the secs active..
PostPosted: October 20th, 2013, 7:45 am
high cpu usage only at starting.
2% ~ 3% after loading.
you can lower the cpu usage by decreasing the glow effect softness
insanty_time_2.xwp [1.08 MiB]
Downloaded 652 times
PostPosted: October 20th, 2013, 7:50 am
Thanks qiancang but I notice two issues:
1) One txt appears deleted (between to AM and 12). Is the number 42 that is missing.
2) One second txt remains visible..
Look:
PostPosted: October 20th, 2013, 7:54 am
i deleted all the "min" components :)
the second issue does not happen on my PC
PostPosted: October 20th, 2013, 7:59 am
I see that you used the empty background image that I made it at at the beginning!
About the num 42 I found it! You just used n41 twice! :)
The sec issue why happpens to me..?
Edit: I notice that the sec number that remains "on" is the sec AT THE MOMENT WHEN THE WIDGET LOADS.
PostPosted: October 20th, 2013, 8:10 am
no such problem on my PC, maybe someone else can help to test this widget.
PostPosted: October 20th, 2013, 8:14 am
Ok qiancang. Thank you VERY MUCH for you help! :)
PostPosted: October 20th, 2013, 12:19 pm
meme what do you think..? Download the qiancang's widget to check the alternative code..
PostPosted: October 20th, 2013, 4:57 pm
qiancang code is much more efficent than mine and the renaming of some components allows a easier way to address the components.
Tested qiancang code and I can see the problem you are describing, one of the second displays stays permantly on, as you said it seem to be the first one used when the widget starts. BUT it does not do it everytime you startup :?:
It will also do it if the widget is running and you select edit to start designer. :o
Seems to be related to timing and system load, if others can not see this problem they my have faster PC's with more resources. :?:
PostPosted: October 20th, 2013, 9:08 pm
one mistake: please replace if(s!=mm) with if(s!=m) in about line 55
PostPosted: October 21st, 2013, 1:32 am
Ok qiancang did it! Here is what I notice:
1) The second number that remains "on" is the sec at the moment when the widgets loads. (yes, EVERY TIME)
2) Waiting for one minute when the seconds pass from the same number, then the "permanent" number disappears, all works ok for 4-5 secs but then one more num/text remains steady again....
In the meme's script there is this part:
ResetAllColors();
We can combine this with your script qiancang? Maybe this can fix the problem..
The fact is that using meme's script, to make the seconds work properly we need to delete the "if (eval(datetimecore1.get("%Second")) == 0)" part. Works (!) but consums a lot of ram.. With qiancang script all work too with minimum consumption but there is this issue with the seconds..
PostPosted: October 21st, 2013, 2:05 am
Guys here is another script that digigamer sent me on DA .The seconds function is missing but we can try to add it and see if works:
//store reference to last, reset display on change
var lastmin = null;
var lastweek = null;
var lasthalf = null;
var lasthour = null;
thisweek = datetimecore1.get("%WeekEn");
thismin = datetimecore1.get("%Minute0");
thishalf = datetimecore1.get("%AMPM");
thishour = datetimecore1.get("%Hour0");
//act if changed
if(lastmin != thismin)
if(lastmin != null) {
eval("min"+lastmin).Effect.Glow.Enabled = false;
eval("min"+lastmin).Font.Color = rgba(0,0,0,255);
eval("min"+thismin).Font.Color = rgba(0,20,171,255);
eval("min"+thismin).Effect.Glow.Enabled = true; //minute0
if(lasthalf != thishalf) {
if(lasthalf != null) {
eval(lasthalf).Effect.Glow.Enabled = false;
eval(lasthalf).Font.Color = rgba(0,0,0,255);
eval(thishalf).Effect.Glow.Enabled = true;
eval(thishalf).Font.Color = rgba(197,16,16,255);
if(lasthour != thishour) {
eval("h"+lasthour).Effect.Glow.Enabled = false;
eval("h"+lasthour).Font.Color = rgba(0,0,0,255);
eval("h"+thishour).Effect.Glow.Enabled = true;
eval("h"+thishour).Font.Color = rgba(0,93,171,255);
if(lastweek != thisweek) {
if(lastweek != null) {
eval(lastweek).Effect.Glow.Enabled = false;
eval(lastweek).Font.Color = rgba(0,0,0,255);
eval(thisweek).Effect.Glow.Enabled = true;
eval(thisweek).Font.Color = rgba(41,1,214,255);
lastmin = thismin;
lastweek = thisweek;
lasthalf = thishalf;
lasthour = thishour;
PostPosted: October 21st, 2013, 3:45 am
I start a third test widget using the code by digigamer. I'm starting to add the seconds txts in the widget and add the extra similar fields in the script for the seconds... Let's see how the widget will work..
PostPosted: October 21st, 2013, 3:49 am
So this is what you asked! Isn't it? With blinking seconds???
Another version: Shows seconds in green, minutes in royal blue and avoids conflicts between seconds and minutes falling at the same time ex: 04:16:16 PM
File comment: Screenshot (scaled to reduce my data)
(Default Image removed to save my data... currently running mobile broadband, costly. Just generate a new one.)
PostPosted: October 21st, 2013, 4:03 am
Hahaha I knew it!! DG you're my hero! :D
The default image was already in the folder so there is no problem add a new one and the defaut violet colour for the week days can be changed easily.. (I hope changing one colour will don't break the function again! :lol: )
An enormous THANK YOU digigamer!!! And meme and qiancang of course!
Thank you all guys and sorry to be a trouble with my widget!
