PostPosted: October 9th, 2013, 2:01 pm
Hi, I want to change the position of a widget to certain x and y coordinates. How can I do this by code?
Thanks!
PostPosted: October 9th, 2013, 6:15 pm
This may help... not exactly what you asked, it starts a widget and positions it in the center of the screen.
// start the widget remotely from the main widget
var winX = (ScreenWidth - 480) / 2; // 480 is the width of the widget
var winY = (ScreenHeight - 720) / 2; // 720 is the height of the widget
startupWidget("YearCalendar",winX,winY); // start and position the widget
PostPosted: October 10th, 2013, 5:46 am
I found a easiest way:
widget.top = 350;
widget.Left = 30;
Yes... so easy :)
Thanks anyway!
