PostPosted: October 8th, 2013, 3:41 pm
Can I push a button on a widget "A" to produce an effect in a widget "B"?
How would the code for it?
I want, by pressing the 1 button on the widget "A" all these things occur in the Widet "B"
function button1OnClick(Sender)
  Text23.text = edit1.Text;
  sleep(500);
  logo.moveTo(99,209,1,1,8);
  image1.moveTo(177,0,1,2,8);
  sleep(1000);
  image4.ScaleTo(1.8,1.8,2,0,1,9)
  image4.MoveTo(-210,22,1,1,9)
  sleep(500);
  box1.moveTo(193,73,1,1,8);
PostPosted: October 8th, 2013, 7:44 pm
Messages can be sent from one widget to another, I do something similar with a pop up calender, parts of the code are below, hope this helps.
// send messages to the remote widget
msg("close","YearCalendar")
msg("hide","YearCalendar")
msg("show","YearCalendar")
//Message code in the remote widget
function widgetOnMsg(MsgString)
if(MsgString=="close") // remote close
close();
if(MsgString=="hide") // remote hide
widget.visible=false;
if(MsgString=="show") // remote show
yearOnClick()
widget.visible=true;
PostPosted: October 9th, 2013, 3:34 am
Excelent!!!!! thanks!!!
If you could upload the two widgets you made, would be great!
Thanks again meme!!
BTW: your code for "blur" works great!
PostPosted: October 9th, 2013, 7:52 am
I wrote all the code in both widgets ... but I can not make them work!
An example:
Main widget:
function button2OnClick(Sender)
Msg("uptext","remotewidget");
(NB: "remotewidget" is the name of the folder where the remote widget is. Should I wrothe the full path?)
Remote widget:
if(MsgString=="uptext") // reduce nombre 1 punto
text1.Font.Size = text1.Font.Size +1;
Which is what I'm doing wrong? what am I missing?
SOLVED!!!
I needed to add "widgetOnMsg" in attribute "OnMsg" in "Functions (widget)"
