PostPosted: September 29th, 2013, 7:46 pm
Hi! I wish to know how can I set blur efect to "text1" through code.
And... how can I set a change of scale trhough code?
Thanks!!!
PostPosted: September 29th, 2013, 11:55 pm
Does this work for blur ?
text1.Effect.Blur.Enabled = 1
text1.Effect.Blur.Softness = 10
PostPosted: October 3rd, 2013, 12:05 am
Do you mean aero blur-behind?
The standard should work fine as described by meme?
PostPosted: October 3rd, 2013, 5:46 pm
standar blur I mean.
I will try whit this described by meme.
Thanks!!
