 Post subject: Saving Text in Memo
PostPosted: September 7th, 2013, 11:14 am
Two questions:
1.So I have a basic widget with a memo, and wanted to know how I can get the text I type in the memo to save itself (as in always stay even when I log back on, unless I re-edit?)
I would be fine with adding a "save" button at the bottom too, I just need to know how to.
2.Also, Let's say if I add a number to my memo with higher value than the number of my second memo, how can I change the color of that?
Say my first memo has the number "3" inputed, and my second memo has the number "2" inputed, could I make it so that the text in the 2nd memo would turn red for example?
-Thanks! ;)
 Post subject: Re: Saving Text in Memo
PostPosted: September 7th, 2013, 12:02 pm
Using the XWidget Designer click on your "memo" component on the left list and then on the right under "Attributes->General Tab" you will see this option "Auto save memo".
On the same tab is the colour option ("Font"), so can choose the colour of each text/memo. ;)
