It is currently June 14th, 2025, 8:15 pm
PostPosted: July 17th, 2013, 2:03 pm
I want to show an item when a song change (like autoshow trayballon)
This code should work?
"Playinfo" also can be show/hide with a button. That's because I used an "if..."
Thanks!
function TitleOnChange(Sender)
if(playinfo.Visible = true)
  playinfo.Visible = true}
else
  playinfo.Visible = true;
  sleep(3000);
  playinfo.Visible = false;
PostPosted: July 17th, 2013, 2:22 pm
Hi Armando!
Please next time for this kind of post/help use the "Help: XWidget Skins/Widget" section...
