 Post subject: Clock/hours sound
PostPosted: July 6th, 2013, 3:38 am
I have a Cuckoo Clock widget and I want to assign the sounds (ticktack and the 12 notifications sounds for the hours)
I have already the 13 sounds in mp3 but I need help with the script code (or not needed?)
For example:
1mp3 file> play at 1:00
2mp3 file>play at 2:00 etc
Also an image that will appear at the same time with the sounds (the open window with the bird)
And of course how create the right click options to switch on/off the sounds...
Thank you!
 Post subject: Re: Clock/hours sound
PostPosted: July 14th, 2013, 11:50 am
viewtopic.php?f=7&t=3345
