 Post subject: Default widget settings
PostPosted: June 19th, 2013, 9:43 am
I currenty installed Android Jellybean theme on my computer and I just wanted to change the position of widgets, delete some and add some of the widgets. When I place the widgets those I want, If I restart my computer, The widgets replaces as exactly same as before.. So is there a WAY that I can customise the widgets and save?
PostPosted: June 25th, 2013, 5:39 am
Please make sure you install the last version of XWidget from http://xwidget.com
