It is currently October 23rd, 2026, 8:21 am
PostPosted: May 26th, 2013, 10:04 pm
hi im pretty new to xwidget so please excuse me this seems pretty obvious.
im trying to determine if the DownloadFile function was successful. I see it takes 3 parameters and the function it self can return boolean but i dont know how to get it.
eg
var status = DownloadFile(p1,p2,p3);
print (status);
//-----------------OR--------------------------------
print(DownloadFile(p1,p2,p3));
DownloadFile(p1,p2,p3);  // this works fine but i don't know if the download was successful. other than the obvious checking the
//widget directory but i need this variable.
In both print instances, in the debugger i get
print: <-- //Nothing
thanks in advance anyone.
PostPosted: May 28th, 2013, 6:11 am
You need write codes in Widget's Event, etc: widgetOnload event
excample widget: http://www.xwidget.com/xwidget/widgets/ ... 8/240.html
PostPosted: May 29th, 2013, 8:00 pm
thank you for your reply.
I had already searched through the forums (throughly if i may add), and had already found that widget.
its a bit complicated for me, but i guess ill have another look.
Users browsing this forum: No registered users and 81 guests
