PostPosted: May 25th, 2013, 4:59 am
I found these for Rainmeter and thought that'd be nice for xwidget:
Source
I would prefer network traffic DL & UL to have separate lines each though.
Could "In: 0.0B and Out: 0.0B" as well as "Local IP and WAN IP" and Uptime be left away?
Maybe to be replaced by the same kind of bars for used space of storage devices.
What do you think?
PostPosted: May 25th, 2013, 5:08 am
The uptime is good and should stay but for the "Local IP and WAN IP" yes I agree that should be replaced by HDD stats...and of course this stupid mail on top..!
But what about the 4 buttons on the bottom?
PostPosted: May 25th, 2013, 5:15 am
Hm, I don't really know Image
PostPosted: May 25th, 2013, 5:28 am
We can just not put them!
..or better add commands for shutdown, sleep and restart! ;)
PostPosted: May 25th, 2013, 5:49 am
Also one more thing that I don't like in this widget. Have you noticed the charts position? When they will be full with graphic, will overlap the text!
PostPosted: May 25th, 2013, 5:56 am
Yeah, that's why the color of the graphs should be different,
or ... to be replaced with bars?
PostPosted: May 25th, 2013, 6:33 am
Yes maybe it'll better with bars..
But you think that at the end is worthing the work for make it for Xwidget...? :?
I always want to see more "particular" designs..
PostPosted: May 25th, 2013, 6:55 am
Hm, I'm afraid I can only do easy & simple.
It will take a long time for me to advance.
