 Post subject: is.gd api
PostPosted: May 23rd, 2013, 3:52 am
is.gd api how to use the widget?
http://is.gd/
create.php?format=simple&url=www.example.com
 Post subject: Re: is.gd api
PostPosted: May 25th, 2013, 10:44 pm
I found a way, he is quite fine with me, but terribly widget hangs.
how to make a thread?
function timercore1OnUpdate(Sender)
     function file_get_contents( url ) {   // Reads entire file into a string
   // +   original by: Legaev Andrey
   // %      note 1: This function uses XmlHttpRequest and cannot retrieve resource from different domain.
   var req = null;
   try { req = new ActiveXObject("Msxml2.XMLHTTP"); } catch (e) {
      try { req = new ActiveXObject("Microsoft.XMLHTTP"); } catch (e) {
         try { req = new XMLHttpRequest(); } catch(e) {}
   if (req == null) throw new Error('XMLHttpRequest not supported');
   req.open("GET", url, false);
   req.send(null);
   return req.responseText;
var echo = file_get_contents('http://is.gd/create.php?format=simple&url=www.example.com');
alert(echo);
PostPosted: May 25th, 2013, 11:34 pm
modify your code a bit!
req.open("GET",url,true);
req.onreadystatechange=function() {
  if (req.readyState==4) {
   var response = req.responseText; //do something
req.send(null);
This is better than GetHttpStrAsync
Note: the code above DOESN'T HAVE ANY RESTRICTIONS! Ignore the warning in your code. That's only for websites.
PostPosted: May 26th, 2013, 12:01 am
I can not ... can you please throw example
PostPosted: May 27th, 2013, 3:45 pm
up.............
PostPosted: May 28th, 2013, 7:18 pm
I had given one, modify your code a bit
     function file_get_contents_async( url ,callback) {   // Reads entire file into a string
   var req = null;
req.onreadystatechange=callback;
req.send(null);
file_get_contents_async('http://is.gd/create.php?format=simple&url=www.example.com',function() {
   alert(response);
PostPosted: May 28th, 2013, 9:31 pm
Knocks out a syntax error.
Untitled2.XWidgetPkg [6.65 KiB]
Downloaded 417 times
PostPosted: May 28th, 2013, 10:17 pm
[09:13:59 629]: [Script Error (line:23,char:3) ]
Nothing comes of not getting an answer ... alert function does not work
PostPosted: May 28th, 2013, 10:18 pm
Syntax Error ...
PostPosted: May 29th, 2013, 6:32 pm
Oh! you could correct that, a simple bracket was missing...
Ok ok, I've streamlined the methods... you can now reuse with simple copy paste...
Grab the modified widget
Untitled2.XWidgetPkg [6.66 KiB]
Downloaded 404 times
