 Post subject: Alert value
PostPosted: May 20th, 2013, 3:58 am
:P hello new to site just have one question how to enable alert value just like in samurize like when value drops or increases oh yes not very at jscript
 Post subject: Re: Alert value
PostPosted: May 20th, 2013, 6:37 am
You mean something like this?
viewtopic.php?f=7&t=2917
PostPosted: May 20th, 2013, 9:39 pm
i assume u mean u are not very good at javascript.
neither am, but only way i can think to get a result like that is with the use of javascript.
eg. using the snippet by jimking led to:
function ramcore1OnUpdate(Sender)
    var ramvalue = parseInt(ramcore1.get("%PhysPercent"));
    if(ramvalue>=80)// your threshold
        alert("Ram is over 80%, lighten up Dammit"); // this will give a popup
PostPosted: May 21st, 2013, 2:52 am
..or this for example: ;)
viewtopic.php?f=11&t=3036
