PostPosted: May 19th, 2013, 6:49 pm
I found the "magical weather" app for iPad:
Source
Would that be attractive enough to be ported over to xwidget?
PostPosted: May 20th, 2013, 4:27 am
I'm almost sure that the right part cannot be done with existing codes (this depends from the weather service.We have not the possibility to know the weather for every hour). Also we can't know the % of rain for the day/s.
The other values are ok but the widget it will be a bit "empty"...
PostPosted: May 20th, 2013, 10:51 am
Oh, I understand.
Thanks for letting me know.
PostPosted: May 20th, 2013, 6:23 pm
Well, the service used in the app is accuweather. In fact we have all these details but the accuweather core doesnot express this. But there is a "dirty workaround" parse the response manually using jscript but as I said, it's dirty!
PostPosted: May 20th, 2013, 6:40 pm
Oh, I like dirty.
PostPosted: May 21st, 2013, 5:02 pm
k.. i'll see
