 Post subject: Json
PostPosted: May 17th, 2013, 10:13 pm
I have an array in Json how to bring one of its values ​​in the label
 Post subject: Re: Json
PostPosted: May 18th, 2013, 5:49 pm
var array = JSON.parse("your json string here");
//use your elements
var obj1 = array[0];
// WRITE YOUR CODE HERE
Note: this code ONLY works in W7 and above...
If you wish to support lower versions of windows then add the following code at the head of your script file:
if(!this.JSON) // check for non-existence of JSON object/functions
//<define a JSON object>
//from https://github.com/douglascrockford/JSON-js/blob/master/json2.js
//download the file and append the contents here
//run the code as usual
//some code accessing json
PostPosted: May 23rd, 2013, 3:43 pm
Something I error knocks.
Here at this link is JSON: http://api.vkontakte.ru/method/users.ge ... =photo_200, status
Spars and need to display text ->> in Lable.
need to display A reference to the awatar ->> component "picture"
Please Help me
PostPosted: May 23rd, 2013, 5:26 pm
This should be the code... what are you using can you provide something
//get the json.. lets say that is stored in a obj
var obj = JSON.Parse("string that you receive");
var uid = obj.response[0].uid;
var firstName = obj.response[0].first_name;
var lastName = obj.response[0].last_name;
var avatar = obj.response[0].photo_200;
Here comes the bottleneck, I don't know how to set the image from a remote source. There's a thread for this but I don't remember which. Search a bit.
PostPosted: May 24th, 2013, 9:59 pm
And how to get a JSON string? In the PHP there is a function file_get_contents.
Example in PHP:
$request = 'http://api.vkontakte.ru/method/users.get?uids=ID&fields=photo_200,status';
$response = file_get_contents($request);
$info = array_shift(json_decode($response)->response);
var_dump($info->photo_200); // URL photo
var_dump($info->status);    // status
If it is not difficult to throw off the project
PostPosted: May 25th, 2013, 11:30 pm
Definitely not but I wont advice to dump your creation.
Use gethttpstr or ActiveX do fetch strings
PostPosted: May 31st, 2013, 9:37 pm
function file_get_contents_async( url ,callback) {
var req = null;
try { req = new ActiveXObject("Msxml2.XMLHTTP"); } catch (e) {
try { req = new ActiveXObject("Microsoft.XMLHTTP"); } catch (e) {
try { req = new XMLHttpRequest(); } catch(e) {}
if (req == null) throw new Error('XMLHttpRequest not supported');
req.open("GET",url,true);
req.onreadystatechange=function() {
if (req.readyState==4) {
var response = req.responseText;
callback(response);
req.send(null);
file_get_contents_async('http://api.vkontakte.ru/method/users.get?uids=1&fields=photo_200',function(response) {
//response is the downloaded string...
//BE WARNED THAT : if download fails no call is made
alert(response);
var obj = (How to insert here response????????????);
alert(lastName);
PostPosted: June 1st, 2013, 5:26 pm
var req = null;
 callback(response);
req.send(null);
 alert(response);
var obj = JSON.Parse(response);;
alert(lastName);
Do all coding between the brackets.
PostPosted: June 1st, 2013, 10:02 pm
I probably already tired but...
response.0 null or not object:
var req = null;
 callback(response);
req.send(null);
function text1OnClick(Sender)
 alert(response);
var obj = (response);
alert(lastName);
Definitions not JSON :
var req = null;
 callback(response);
req.send(null);
 alert(response);
var obj = JSON.parse(response);
alert(lastName);
PostPosted: June 2nd, 2013, 12:58 am
Your JSON source is api.vkontakte.ru?? Then wait a min... i'm seeing what it does
PostPosted: June 4th, 2013, 12:46 am
The problem remains ... the answer comes but does not parse out
PostPosted: June 4th, 2013, 10:50 pm
JSON not defined?? This is because the script framework is not updated.
Use this widget, I've tested, it works.
untitled2(2).XWidgetPkg [11.96 KiB]
Downloaded 436 times
