PostPosted: May 17th, 2013, 9:41 am
Hello,
I am having a terrible time trying to get this to work and would very much appreciate any help.
I am trying to use xwidget to code my own widget to download a 640x480 gif image every minute or so and display it so I can move it around.
I am using two "image" components #1 I bind to photoalbumcore and set the image source to %FileName. #2 is just an underlay border (to border the chart image from below and make it look nice)
Then I use TimerCore set at a 60000ms update timer with:
function TimerCore1OnUpdate(Sender)
DownloadFile("my URL here","achart.gif", "")
My problem is that every time I start the widget I get the latest chart but it never updates the image. so I know that the photoalbumcore is passing the image to my "image1" component but it never refreshes.
PLEASE HELP ME!!!! :-(
PostPosted: May 17th, 2013, 9:44 am
by the way, my photoalbumcore directory is set to widget directory and it grabs the "achart.gif" file from there correctly.
PostPosted: May 17th, 2013, 10:02 am
if you want to display gif, you need to use "gif" component, not "image" component.
PostPosted: May 17th, 2013, 10:19 am
Thanks. It's not an animated gif, it's static and update by the site every minute.
will using the gif component cause the photoalbumcore to correctly pull the updated "achart.gif" file correctly?
PostPosted: June 5th, 2013, 3:09 am
mrrearden wrote:
Hello,
ok heres what i would do...i dont know if the best method but it works for me in a .png case.
var file = WidgetPath+"achart.gif";
var url = // whatever your url to the .gif is.
function TimerCore1OnUpdate(Sender){
    DownloadFile(url,file, "updateGif");
function updateGif(){
    Gif1.Src = "";
    Gif1.Src = file;
scrap the photoalbum core and image1 component and use the gif component as qiancang said.
as i said this is what i would do with a .png case im not sure if would work with .gif
i see this post is a bit aged so if u havent already gotten through good luck.
