 Post subject: Modify a weather widget?
PostPosted: April 30th, 2013, 5:44 am
can this widget called Plain Weather be modified from left picture (original) to right one (modified)?
I personally would not need the refresh button (left) and the button to enter the city (right), could that be placed elsewhere?
The name of the city as well as the current weather condition could be left away, so the widget looks cleaner and neater.
Thank you
PostPosted: April 30th, 2013, 6:06 am
Nice modifications ;) , certainly it' more clear.
Bye!
PostPosted: April 30th, 2013, 3:12 pm
Hi, I noticed tonight, that the icon of the moon does not match to the other icons at all.
Has anyone noticed this yet?
PostPosted: April 30th, 2013, 3:24 pm
As far as I know, the icon set has been taken from here:
plain weather icons by ~MerlinTheRed = source
PostPosted: May 5th, 2013, 5:12 pm
Hello, Cov.
All the changes you want can be done by yourself. xWidget is simple enough to edit the widgets in any way you want. It's as simple as right-clicking on the widget, click edit, select the items you want to delete and delete them, save the changes and reload the widget. With respect to the icons of the moon, I like minimalism to a certain extent. When creating this widget, I liked more the original icons that were used in the original widget (HTC Weather Mod). If you want to change the icons, simply browse to where the widget is installed (Example: My Documents/xwidget/Widgets/Weather Plain Icons - Dark/Icons) and replace the icons for those who are in the icon set.
If you need assistance, let us know.
PostPosted: May 5th, 2013, 9:44 pm
Hey Odyseus,
thank you very much for your response.
That was very helpful.
