 Post subject: Skype Widget!
PostPosted: April 29th, 2013, 3:22 pm
It would be great to do some skype widget... I'm offering to do the design... but I don't know if it's possible to do that complex script... and how could be possible that...
I send you some motivational images...
 Post subject: Re: Skype Widget!
PostPosted: April 29th, 2013, 4:52 pm
The images are really motivational...;)
I'll see if I have time from my studies (and widgets,girlfriends etc...) to code up a bit. But the problem is... there are some options that you want to implement which is very difficult to implement from scripts. :( . If it were a .NET or MFC app then it could be done easily :D
A list of things you want to implement would be a great start...
Nothing is Impossible... Impossible is a word found in fools dictionary.
PostPosted: April 29th, 2013, 5:41 pm
It would be really great!! you can count with my design work!!!
Thanks for you quick reply!!
PostPosted: May 15th, 2013, 4:34 pm
I promised coding for you but I was really busy these days. Hardly getting time to read docs. Finally I got some free time but the script is a mess... I'm working on it (albeit slowly). Just to inform that I'm also interested in making one Skype widget.
And... sorry, but it is not possible to bring contact images from Skype and display it in XWidget. I'll see if there is a workaround.
PostPosted: May 16th, 2013, 6:12 pm
THANKS!!! I am still interested and willing to do my part of the job!
Regarding to bring pictures from skype: we could, in turn, allow one to choose the image you want to display for each contact? (which would be even better! skype does not allow this)
Go ahead!
PostPosted: June 14th, 2013, 7:26 am
Digigamer: look at this. I dont know if its help... I know nothing about codes...
Bye!
here:
http://www.codeproject.com/search.aspx?q=skype&sbo=kw&x=0&y=0
Some entries:
Controlling Skype with C#
Skype Status Changer
Skype Smiley Sender
Some links
http://www.codeproject.com/Articles/13081/Controlling-Skype-with-C
http://www.codeproject.com/Articles/603969/Skype-Status-Changer
http://www.codeproject.com/Articles/37909/Make-your-Skype-Bot-in-NET
http://www.codeproject.com/Articles/494906/Outlook-add-in-integrating-Skype
http://www.codeproject.com/Articles/31009/Skype4COM-Event-Handler-Example-for-ALL-Skype-API-
PostPosted: June 18th, 2013, 7:51 pm
Codeproject :lol: these days I used to spend a lot of time there :lol:
But unfortunately, for somedays, and on... my hard disk has bricked and I don't have xwidget to experiment. Currently, I'm doing all my net chores with a Fedora live cd... no hard disk, hard times goin on... :cry:
