PostPosted: April 29th, 2013, 3:12 am
Can this graphic be used for creating a whole set of system monitoring widgets?
I'm not really sure about the design.
Maybe the numbers should read 10, 20, 30 .... 100?
Maybe the strokes are too strong?
Maybe the needle needs to be sharper at the end?
Maybe the last strokes should be grey as well instead of orange?
I was thinking of the following gauges:
• CPU Load
• CPU Temperature
• RAM Usage
• HDD Usage (for each HDD / SDD / USB Key one gauge)
• Download Speed
• Upload Speed
Important is a smooth (not jumpy) movement of the needle.
Thank you
PostPosted: April 29th, 2013, 7:18 pm
Ok, I have been told that I need the following graphics:
• a background base
• a needle
• a center circle (of the needle)
• a scale / line numbers
I will try to get this done.
If I come up with the required graphics, can someone help me creating this widget please?
Thanks
PostPosted: May 13th, 2013, 2:35 pm
I have asked the creator of the gauge whether I could have the single graphics.
He replied yesterday, that he will have to look for them, but they are in cpt-Format.
Can you use them for xwidget or do they have to be converted into a particular format?
Thanks
PostPosted: May 14th, 2013, 3:03 am
I have received the cpt-File. It's only 692 KB large.
Have tried to read it with IrfanView but it didn't work.
Would anyone be able to read the file?
PostPosted: May 14th, 2013, 6:26 am
... es scheint ja nicht so einfach zu sein CPT-Dateien zu bearbeiten ...
Vielleicht kannst Du denjenigen, von dem Du die CPT-Datei hast, fragen, ob er sie für Dich aus seinem Programm heraus in einem für Dich bearbeitbaren Dateiformat exportieren würde? "Paint-ShopPro" exportiert z.B.:
BMP, CAL, CALS, CLP, CUT, DCX, DIB, EMF, EPS, AI, PS, GIF, HDP, WDP, IFF, IMG, JP2, J2C, J2K, JPC, JPX, JPG, JIF, JPE, JPEG, MAC, MSP, PBM, PCX, PGM, PIC, PPM, PNG, PSD, PSP (PSP IMAGE FILES), RAS, RAW, RIF, RIFF, RLE, SCT, CT, JPS, PNS, TGA, TIF, TIFF, WBMP, WBM, WEBP, WMF
PostPosted: May 14th, 2013, 4:45 pm
Hallo Dagedee,
der Autor hatte mir die CPT Datei mit folgender Bemerkung zugesand:
I attached the picture containing all the parts you need.
It was the nearest thing I found similar to the old picture
you sent. If you do not have Corel Photopaint or you
cannot import this format, just let me know and
I'll export its parts as png.
Da ich die Datei weder mit IrfanView noch mit Photo-Scape öffnen konnte, habe ich ihn nun gebeten, sie auf PNG zu konvertieren.
Jemand im ComputerBase Forum hat mir parallel dazu zugesagt, eine Vektorgrafik (SVG) nach meinen Vorstellungen anzufertigen.
Ich habe von Grafikbearbeitung nur wenig Ahnung, muß mich aber bald mal wirklich näher damit beschäftigen.
PostPosted: May 16th, 2013, 1:09 am
Hi Dagedee,
ich habe gestern die Grafiken im png-Format erhalten.
jimging wäre bereit dazu, daraus ein funktionierendes Widget zu machen.
Wenn alles klappt, ist es bald fertig.
Inzwischen habe ich auch die o.a. Vorabversion von einem online-Freund erhalten. Er hat die Grafik genauso umgesetzt, wie ich es beschrieben habe - einfach fantastisch. Es sieht wie eine konsequente Weiterentwicklung der Grafik aus Posting #1 aus, mit einer feineren Skala und einer dünneren Nadel (inklusive Nadelspitze) - beides sogar mir leichtem 3D Effekt. Er hatte mich gefragt in welchem Format ich es gerne hätte. Habe ihm geantwortet, daß png ausreichend wäre. Keine Ahnung ob der Xwidget-Designer mit SVG überhaupt umgehen kann.
PostPosted: May 16th, 2013, 6:17 am
Hi Cov,
... bin ja echt gespannt auf Dein erstes Widget! :D
Für die Widgets braucht man hauptsächlich PNG-Bilder, die unterstützen auch Transparenz. Wenn Du an Deinem Widget hinsichtlich der Farbe, Größe etc. noch was ändern willst, solltest Du die SVG-Datei auch nehmen. Die kannst Du mit Inkscape s.o. öffnen und bearbeiten. Für Dein Widget brauchst Du übrigens für jedes Teil das irgendwas machen soll, ein einzelnes PNG-Bild. Die Nadel muss z.B. ein einzelnes Bild sein, "50%" darf nicht draufstehen - das macht man dann im XWidget-Designer. Ich fand es zu Anfang ganz hilfreich mir die Standard-Widgets (Eker-Widgets) genauer anzusehen. Da braucht man eigentlich nur die Bilder auszutauschen und schon hat man ein eigenes Widget ... :)
PostPosted: May 16th, 2013, 7:33 am
Vielen Dank, Dagedee!
Sobald die neuen Widgets heiß aus der Presse kommen, stelle ich sie hier rein.
PostPosted: May 16th, 2013, 4:45 pm
All my widgets are ready! :D
Right click on the HDD Gauge for select drive.
Check:
http://oi41.tinypic.com/bjigbt.jpg
PostPosted: May 16th, 2013, 5:49 pm
Super !!
