 Post subject: Detecting Player State
PostPosted: April 24th, 2013, 12:01 am
Hi everyone,
How can I detect player state whether it is playing or the user has paused or whether it is stopped?
I'm currently using the isPlaying variable but that doesn't distinguish between paused or stopped?
Is there something like isStopped.
If not then plz tell, i'll go to activex controls.
Regards,
Digigamer
PostPosted: April 27th, 2013, 3:20 am
maybe you can use the %playtime to judge the player is paused or stopped.
when the isPlaying variable is false, if playtime == 0, we can treat it as isStopped.
PostPosted: April 28th, 2013, 5:35 am
Thanks a lot.
But i'm afraid, it's not that effective. Since I intended to depend on this to show an animation but everytime a track changed, it also triggered the condition.
But anyways, thanks a lot. It helped me to detect another state. If media player is running.
if (!%ISPlaying) && (%title == ' ')
// then we can assume media not is loaded and player is not running.
So, now showing on off state instead of running or not running! :D
Regards,
digigamer
PostPosted: April 29th, 2013, 2:19 pm
you can use the %IsPlaying tag to control the image components' src
format core data: %IsPlaying.png
playerpauseplay.XWidgetPkg [11.98 KiB]
Downloaded 303 times
facebook:http://www.facebook.com/ZhaoKenneth
weibo:http://weibo.com/102030456
twitter:http://twitter.com/colawings
DeviantArt:http://kenneth117.deviantart.com/
PostPosted: April 30th, 2013, 9:10 pm
Thanks, but that's not what I was trying to achieve. I've already implemented that. I wanted to know wheter the track was paused or stopped. And that cannot be done without WMP ActiveX.
