PostPosted: April 15th, 2013, 10:43 am
Hello.
Please - only last image visible, other looks like second on this screen or just don't appear.
  images[num] = Image.Clone(icon2)
  //images[num] = Image.Create(widget); <--- don't work. How to use this properly? I tried many variants, but nothing except upper line works.
  images[num].parent = frame;
  images[num].Visible = true;
  images[num].top = 10;
  images[num].Left = 5;
  images[num].core = shortcutlistcore1;
  images[num].Coreformat = "%item"+num+"_Icon";
  images[num].OnClick = "!Open";
  images[num].OnMouseEnter = "OnMouseEnter";
  images[num].OnMouseLeave = "OnMouseLeave";
And has xwidget a manual like http://docs.python.org/2/library/ ?
Thanks in advance.
sao3.zip [1.27 MiB]
Downloaded 330 times
PostPosted: April 15th, 2013, 4:10 pm
How to create image with js code:
var newImg = Image.Create(widget);
  widget.InitControl(newImg);    //uses this function to init control
  newImg.parent = root;
  newImg.src = "Icon.png";
  newImg.left = 50;
  newImg.top = 100;
  newImg.width = 200;
  newImg.height = 200;
  newImg.OnClick = "open1";
//  newImg.bringtofront;  //if you need bring image to front
PostPosted: April 15th, 2013, 6:10 pm
Thank you, it works.
  newImg.parent = frame;
  newImg.core = shortcutlistcore1;
  newImg.Coreformat = "%item"+num+"_Icon";
  newImg.top = 10;
  newImg.Left = 5;
  newImg.width = 45;
  newImg.height = 45;
  newImg.WrapMode = 3;
  newImg.OnClick = "!Open";
