PostPosted: April 6th, 2013, 5:15 pm
Tony could you pls tell me what actually does this option "AlwaysForwad" and when must be applied..?
Thank you
PostPosted: April 7th, 2013, 4:19 am
Rotator control's property "AlwaysForwad" used when it is a Clock handle
if you used for a CPU usage, please uncheck it, then when the cpu usage down from 50 to 10, the Rotator not get problom of animation
PostPosted: April 8th, 2013, 12:36 pm
I see! Thank you....
