 Post subject: webparsercore help
PostPosted: March 16th, 2013, 10:20 am
I am working on a widget to read info from the uTorrent webui, which if you log in with /?list=1 on the end of the address, returns a text based list of torrents.
I have entered the address into webparser core and entered a few regular expressions.
In the text box bound to the webparser core, I inserted some of the %Stringindex1 , 2, 3 etc
But in the text box I see the literal text %Stringindex1 and not whatever value is returned by the regular expression.
Am I missing something? The url I am using is http://username:password@127.0.0.1:8080/gui/?list=1
I, of course, actually entered the correct username and password.
This works for rainmeter etc. and I can view the address in chrome just fine.
 Post subject: Re: webparsercore help
PostPosted: March 18th, 2013, 5:44 am
hi, can you list of your regular?
PostPosted: March 18th, 2013, 6:35 am
At this point I am trying to get anything to show up.
For instance, I know the word torrent appears on the page. everytime.
If I type in "torrent" nothing shows up. I see text above the box that says to quote things in "".
Another one that should work is, "/"(.*)/"", with anything surrounded in quotes being what is returned.
PostPosted: March 22nd, 2013, 12:16 am
Reading this WebParser Tutorial helped me get mine working, even the auto login
just pick out what is relevant to xwidget http://docs.rainmeter.net/tips/webparser-tutorial
Note: do not put the RegExp inside quotation marks xwidget does it for you.
