It is currently October 23rd, 2026, 5:39 am
PostPosted: February 9th, 2013, 9:44 pm
Hello everybody,
I created a football table widget, using webparsercore which works fine so far.
Now I would like to highlight my favourite team.
How could I manage that?
Possibilities:
1. Highlight the complete line/layer (all lines are different layers) <- preferred (e.g. different background colour and/or text colour)
2. Highlight only the team name (text colour)
Many thanks in advance.
PostPosted: March 4th, 2013, 11:27 am
The way I would do it is by putting all the layers in an array, then looping through them checking text.
layers = [layer1, layer2, layer3];
favoriteTeam = "Patriots";
//after loading the feed or updating favorite team:
for(int i = 0; i < layers.length; i++){
    if(layers[i].text == favoriteTeam){ //or maybe "layers[i].text.indexOf(favoriteTeam) != -1"
        layers[i].Background.SolidColor.Enabled == true;
    } else {
        layers[i].Background.SolidColor.Enabled == false; //removes background from old favorite team layer
That code isn't tested, it's just a quick example I wrote while glancing at my own skins.
Hope that helps you.
deviantArt profile
My Widgets:
Game Specials v1.1
PostPosted: March 5th, 2013, 12:42 am
Thanks a lot for your reply :)
I've tried your suggestion but could not really manage it, which is probably caused by my lack of JavaScript.
So I created a very simple widget:
layer1
   text1 (="Patriots")
layer2
   text1 (="other Team")
I changed the background colour for both layers to red (but left it disabled).
Then I took your code and copied it into the code window, trying "if(layers[i].text == favoriteTeam)" and "layers[i].text.indexOf(favoriteTeam) != -1".
Now I was expecting, the layer1 background turns to red but that was not the case (for both). :?:
My original widget has this kind of structure (with 2 additional sliders)
matches [layer]
   match1 [layer]
      hometeam
      guestteam
      result
   match2 [layer]
      hometeam
      guestteam
      result
Sorry for being a bit dummy but could you give me more hints and tell me where is my mistake (in understanding)?
And do I have to create a new function myFavTeam (which has to be loaded "On Change" for each layer)?
