PostPosted: January 11th, 2013, 5:55 pm
I have several shotcutcores in a widget a wish to change the settings of the shortcuts via code, can anyone assist with the syntax.
I can add "Menu items" that use !SetPath= & !SetIcon= with the Binding core-auto binding current object core, selected.
This works, so you can right click on any shortcut and then it will set a path or icon, but I wish to do it from code.
How can do a similar thing in code? Something like...
ShortCutCore.shortcutcore1.DisplayName="hello";
or can I use !SetPath= & !SetIcon=
But I can not get it to work...
How can I achieve the same as the "auto binding current object core" ? so the code runs on the currently selected object core.
Thany you for any assistance :D
PostPosted: January 11th, 2013, 6:41 pm
you can uses code :
  shortcutcore1.cmd(null, "!SetIcon=icon.png" );
PostPosted: January 11th, 2013, 8:10 pm
Thank you Tony that works fine to change the settings for Path and Icon but what about DisplayName ?
Is there a !DisplayName= that can be used to edit the display name ?
Also how can I achieve the same as the "auto binding current object core" ? so the code runs on the currently selected object core?
I can get the name of the object requesting the code with
function OnMouseDown(Sender)
sender.name
But how to I find the shortcutcore? for that object ?
Your assistance is greatly appreciated :)
PostPosted: January 16th, 2013, 12:06 am
The DisplayName will auto set by "!SetPath="
