Post new topic Reply to topic  [ 16 posts ]
 Post subject: Round Progressbar
PostPosted: December 22nd, 2012, 11:00 pm
Hi all. I have one question: how to make a round progress bar?
 Post subject: Re: Round Progressbar
PostPosted: December 25th, 2012, 7:28 am
Progressbar- property-sharp- round corner
PostPosted: December 26th, 2012, 3:30 am
Tony, thanks. But I tried, could not do it. Can you help?
Download from here: (+)
PostPosted: December 27th, 2012, 3:20 am
Hi, maybe you are thinking about something like this?
muziko.zip [81.8 KiB]
Downloaded 437 times
PostPosted: January 7th, 2013, 8:40 am
No, circle progress bar with my images.
PostPosted: January 8th, 2013, 3:13 am
Could you upload it? Perhaps we find a solution.
PostPosted: January 8th, 2013, 9:08 am
http://www.premiumpixels.com/freebies/circular-progress-bars-psd/ - Volume control with this PSD.
PostPosted: January 11th, 2013, 2:10 pm
Got this for the first example.
circleprogress.zip [146.83 KiB]
Downloaded 470 times
PostPosted: January 12th, 2013, 4:31 am
Dagedee wrote:
Got this for the first one, for the second - I don't know. Maybe someone else knows how to achieve it.
circleprogress.zip
I need without background. Make with this images - https://dl.dropbox.com/u/32655885/Desktop.rar
PostPosted: January 14th, 2013, 2:26 am
I found a solution now, it works with a "NumbImage" but not with your psd file. As far as I understand volume control can show "0 - 100 % " or "%TenthVolume" i.e. steps of 10. Your example has 36 items, i.e. you can only get a volume range from 0 - 36 % or 100 % at the 10th item. Thus, you need 100 or 10 items to achieve 0 - 100 % volume. (If somebody knows another solution I would be curious to learn it. :) )
example with 10 items ↓ - mouse wheel up/down to change volume
circle_progress.zip [37.55 KiB]
Downloaded 445 times
PostPosted: January 14th, 2013, 8:48 am
That is good. But I wanted, to look exactly the same as in the PDS. Therefore it is necessary to add a circle progress bar in XWIdget. ;)
PostPosted: January 17th, 2013, 3:15 am
I've got another idea ... took an image with 4 items for every step of 10 (to get 100 % volume).
It looks this way ↓ - mouse wheel up/down to change volume
... I wonder if you will like it, because there are 40 items instead of 36 ;)
circleprogress.zip [52.58 KiB]
Downloaded 492 times
PostPosted: January 17th, 2013, 7:33 am
Dagedee, thank you so much! :)
PostPosted: January 17th, 2013, 7:35 pm
circleprogress.zip
good job
PostPosted: January 18th, 2013, 6:53 am
You're wellcome! :)
PostPosted: January 18th, 2013, 6:54 am
circleprogress.zip
good job
Thank you! :)
