 Post subject: Widget position.
PostPosted: December 21st, 2012, 4:59 pm
Hello.
I am editing now one widget for personal use. Unfortunately, I dont have a lot of time to study the tutorials to the xwidget, anyway almoust everything I needed, I already did, the interface is quite understandable.
But there is one problem - I use windows taskbar at the top of the screen, and I want to locate the widget at the bottom of the screen. By default widget make indent to give the place for taskbar. But I need it with no indentation. I been tryed a lot of options, but after the reset it always does this indentation.
Please help to decide.
 Post subject: Re: Widget position.
PostPosted: December 22nd, 2012, 5:18 am
Hm. I better upload widget here.
Please help to remove the indentation at the bottom. :|
File comment: Widget
Test.7z [122.32 KiB]
Downloaded 349 times
PostPosted: January 17th, 2013, 7:49 pm
widget.top = ScreenHeight - widget.Height;
