PostPosted: December 7th, 2012, 7:58 am
:roll: Hi, I want to add font color change option in widget, but I don't know how to do this??
Please Help...!!
________________________________________________
& How add player button color change option in widget??
Please Help qiancang, tony & other friends...!!
@ILOVEMYINDIA...
My fb profile @
find on deviantART @
PostPosted: December 10th, 2012, 7:20 am
Hi, you can change the color of a font by adding a "MenuItem" in the menus section and some code wich has to be pasted in the curly brackets after "function menuitem1OnClick(Sender)". This will be added by double clicking in the area below "Event/OnClick".
This code is part of qiancang's "circle player" viewtopic.php?f=11&t=2317
Another example with some more features is in his "Flying Cubes" widget http://xwidgetsoftware.deviantart.com/g ... 2#/d5fljm9
fontcolorchange.zip [3.75 KiB]
Downloaded 362 times
PostPosted: December 10th, 2012, 7:55 am
Thanks....!!
@ILOVEMYINDIA...
My fb profile @
