 Post subject: Help with button Find !
PostPosted: November 27th, 2012, 8:59 pm
Hi friends need help :shock:
I look edit "tsf_ui_folder_box"
I Have questions please any help me?
1 - I thought he could find the applications but only says Tools
2 - the marked image, What is the code so that it can find the applications, inside the box
3 - As I write this, you can find the application, in the box
files are attached
tsf_ui_folder_box.rar [46.9 KiB]
Downloaded 331 times
File comment: error
No soy religioso en absoluto. Pienso que la fe es algo que te da fuerza.
Creo en el destino y creo que las cosas suceden por una razón,
pero no creo que haya un poder superior.
PostPosted: November 27th, 2012, 10:41 pm
It does not have search function. That's the name of the box helping you find different boxes easily.
PostPosted: November 28th, 2012, 9:35 am
you can import some code so that it can find
anyone have any xwidgets have the option to search for applications
