 Post subject: New Widgets
PostPosted: August 29th, 2012, 8:33 pm
I just downloaded a new widget and I would like to know how do I add it to the program.
thank you for this . I was using rainmeter but it was to complicated this is much easier.
I am a new user so thanks ahead
:D :D
 Post subject: Re: New Widgets
PostPosted: August 29th, 2012, 8:50 pm
double click xwidget
PostPosted: August 30th, 2012, 8:10 am
I am sorry is this suppose to work on windows 7 which is what I have . I CLICK on the widget after download but it does not open .anything I should do
PostPosted: September 1st, 2012, 12:52 am
Hi,You need download and install last version of XWidget( http://xwidget.com ) and run it ,then you can install skin with double click the widget package file.
