PostPosted: August 19th, 2012, 8:24 am
Hi! I'm making a new widget, and I added to the right-click menu two buttons: Reflection Off and Reflection On. The buttons should Enable and Disable the Reflection of the main docking box, but only the Reflection Off works. Here is the code:
function ReflectionOnClick(Sender)
  if(Background.Effect.Reflection.Enabled = true)
    Background.Effect.Reflection.Enabled = false;
    widget.Height = 605;
function ReflectionOnOnClick(Sender)
  if(Background.Effect.Reflection.Enabled = false)
    Background.Effect.Reflection.Enabled = true;
    widget.Height = 675;
Thanks for the help!
Best regards,
Nutu'
PostPosted: September 6th, 2012, 5:36 am
Hi , Nutu , your code has one problem
if you want to judge , you need to use "==" , but not "="
the same effect using only one right-click menu button:
function menuitem1OnClick(Sender)
  Background.Effect.Reflection.Enabled = !Background.Effect.Reflection.Enabled;
  widget.height= 1280 - widget.height // 605+675=1280
PostPosted: September 9th, 2012, 4:58 pm
Thanks a lot. It works now :D
Users browsing this forum: No registered users and 82 guests
