 Post subject: Drag&Drop
PostPosted: July 31st, 2012, 9:44 am
Good Day! How can I make the drag&drop in the XW? For example there is an image. If you drag and drop files on it, they move to a specific folder (Dropbox folder)? How can I do? ;)
 Post subject: Re: Drag&Drop
PostPosted: July 31st, 2012, 11:09 pm
Hi, You just need:
1. add a folderCore A and set A path property
2. Binding the image to the folderCore A
3. Check the image property [Others]--[Accept drag and drop file]
4. run
then, when you drag and drop a file/folder on to the image,the file/folder will be moved into the folderCore's path folder.
PostPosted: August 1st, 2012, 1:37 am
Thank you so much, Tony :)
