PostPosted: July 30th, 2012, 12:03 pm
hello :D
i need some help with the slide animation
i have a folder dock what i want is for the folder to slide up on Mose Enter
the pic will explain
PostPosted: July 31st, 2012, 1:38 am
You can add a SlidePanel control ,and drag drop image1/image2/image3 under the slidepanel at left-tree-list
then, you just need set the slidepanel's property to slide with animation,etc: slided, offset value , slide animation type/duration...
you can look this widget as template: http://www.xwidget.com/xwidget/widgets/ ... 17/41.html
PostPosted: May 15th, 2013, 2:56 am
Really good.I will concern about it.
__________________________________________________
Diablo 3 Gold;WOW Gold;Diablo 3 Gold Kaufen;Guild Wars 2 Gold
