 Post subject: PhotoAlbumCore Code
PostPosted: December 27th, 2019, 9:25 pm
Hi
I try to change the path of my photoalbumcore but my code not work can you help me ?
function BTNOnClick(Sender)
  photoalbumcore1.cmd(null,"!SetPath=C:\\Pics");
But not work...
Thx :) :) :)
// ===== Contact ===== //
https://discord.gg/9vyhv3F
// ===== My Widget ===== //
 Post subject: Re: PhotoAlbumCore Code
PostPosted: January 4th, 2020, 9:47 am
Hi Rom and Happy New Year! :)
You mean something like this?
I used this code
function button1OnClick(Sender)
  photoalbumcore1.cmd(null,"!ChangeFolder")
test.xwp [6.17 KiB]
Downloaded 854 times
PostPosted: January 7th, 2020, 6:37 pm
Yes happy new year
Regarding the code, what I would have liked is a button that directly selects a defined folder if possible.
When I click on the OverWatch icon I would like it to change the path of the photoalbumcore if possible of course
Thank you :) :) :)
PostPosted: January 8th, 2020, 2:10 am
I see. All the widgets until now use custom selection for the path. The manual selection it's always better, because there is no restriction.. Think about it.
In any case I will try to find that code.. :)
PostPosted: January 8th, 2020, 7:49 am
This code works maybe ?
photoalbymcore1.cmd(null,"!ChangePath=C:\\Pics");
Ty JimKing ;)
PostPosted: January 8th, 2020, 10:06 am
Ty JimKing ;)
There is an error there. It's photoalbumcore1.cmd
I tried placing a folder directly to C:\ named "Pics" but the widget doesn't show anything.
I made some changes but no luck. Seems that this code doesn't work. It needs different approach.
Unfortunately my knowledge about js is limited.. :roll:
PostPosted: January 8th, 2020, 1:27 pm
Yes i have see this error, but I try to do like you but no results, and I too am a beginner of JS ..
Maybe with location.path function ?
https://www.w3schools.com/jsref/prop_loc_pathname.asp
PostPosted: January 10th, 2020, 9:08 am
Maybe this will work, but we need to find the format.. JS is very sensitive.
I'll continue to search, but I think that it's not a big deal. You can always use the code of my test widget. It needs a couple of clicks to set the path.. :)
Users browsing this forum: No registered users and 72 guests
