PostPosted: September 1st, 2018, 7:09 am
Hi, i have purchased Xwidget pro version recently and installed it successfully on my computer. But i wonder if someday i will need to install it on another computer, what should i do? is it possible?
PostPosted: April 28th, 2019, 2:00 am
Yes, as far as I know you can install it on as may computers as you like.
I tried to find the license terms but I couldn'''t find them but in practice if you enter your code you can run it.
Users browsing this forum: Google [Bot] and 150 guests
