It is currently October 23rd, 2026, 1:11 am
 Post subject: language problem
PostPosted: August 21st, 2018, 8:53 am
After updating, my XWidget App is in an unknown language. I cannot figure out how to change back to English.
 Post subject: Re: language problem
PostPosted: August 21st, 2018, 12:56 pm
What do you mean..? Unknown language in which part?
Because we never had this problem...
You mean for the clock widgets, weather, menus..?
Please give me more details so I can help you.
PostPosted: August 26th, 2018, 7:38 am
My entire XWidget program is now in another language-it looks oriental (Korean, Japanese, etc.) and all the apps (calendar, etc.) display in those characters, including the main menu. Because I do not understand the language I do not know where to go in the program to change it back to English. I have tried re-installing the program with no change in the issue.
PostPosted: August 26th, 2018, 1:14 pm
1. You're talking about the Android app? (I ask you because some users post in the wrong section)
2. We never had this kind of report before since ALL the versions from the first one are created exclusively in English. You use the official verion from Playstore?
I will send a pm to the dev to check but seems really strange..
PostPosted: August 26th, 2018, 11:51 pm
Reply from Tony:
Fixed
Uninstall the old version and reinstall or delete the file xwidget/appdata/lang/default.txt
PostPosted: August 27th, 2018, 7:19 am
Thank you Tony. After deleting all languages except English and re-starting the app, the problem was solved.
And this issue was on my Windows 10 Home desktop system, Windows 10.0.17134 Build 17134, Acer aspire TC-280, AMD A10-7800 quad core processor, 2 TB hard drive, 12 GB RAM. Again thanks for your help.
Users browsing this forum: No registered users and 83 guests
