 Post subject: Key Recovery
PostPosted: June 30th, 2018, 12:55 am
So, the website is really bad...and there does not appear to be any way to recover my license, or not one that is clearly and concisely explained or displayed. So, how do I recover my License Key please?
 Post subject: Re: Key Recovery
PostPosted: June 30th, 2018, 3:29 am
The forum is pretty easy and simple SanguinemUK, separeted in 3 sections: XWidget for Android, XWidget for PC and XLaunchpad.
The key has been sended after the purchase to your personal email. If you have problem to recover it please send an email to the Dev Tony as in these cases should be done. Contact the Dev..
support@xwidget.com
Thank you
PostPosted: June 30th, 2018, 7:57 am
Hi, Thanks for your purchase, the serial number/key are auto send by Avangate.com. I had re-send the serial number/key to your email.
Users browsing this forum: Google [Bot] and 149 guests
