PostPosted: August 5th, 2017, 7:08 am
OK I installed a bunch of whether widgets. They work but I can't change the 12/24 or the C/F. It says right click. There is no right click. There is long press but then I just get the option to resize or moving the widget. No way to change what I need to change. What am I doing wrong??
PostPosted: August 5th, 2017, 9:55 pm
After add a widget on your home screen, touch on the widget to show the 'right click pc style' menu.
From there you can change directly the 12h/24h or the C/F unit
Tutorials
viewforum.php?f=23
PostPosted: August 5th, 2017, 11:04 pm
When I just click the newly placed widget, I get no menu at all. I can long press but then it gives the option to resize or move like anything you long press.
PostPosted: August 6th, 2017, 4:14 am
The long press works for the launcher's settings only.
1) Just add a widget and simple touch on. This is the general mode for ALL the xwidget's widgets.
2) Check if you have the "click event" disabled through the widget settings. So go to num3..
3) Try to remove completely the widget from the homescreen and re-add it
4) Check if you use a launcher that supports the up/down position of the widgets, if you have put the xwidget widget in a lower position.
Tested and the app works without this problem on S7 and S7 Edge with 7.0
I can't think any other case for your problem..
PostPosted: August 6th, 2017, 6:53 am
Weird then. I'm using the default Samsung VIZ launcher
PostPosted: August 6th, 2017, 7:26 am
I will forward your report to the Dev to check it for the next version. If you can test the app on other Samsung phones..
We have already test it to many Samsung phones with Android versions from 4.0.3, 4.4.2, 5.0, 6.0+ and 7.0 and all work fine..
PostPosted: August 6th, 2017, 8:51 am
I got around it by going into the edit widget and change the core settings to 12hr and unclicked metric then saved
