PostPosted: April 20th, 2017, 6:14 am
Question for you lot here re: dialogs.
When opening a file open dialog box, is there a method to add a file filter to the input of the dialog function?
I want to do something like this:
var validTypes = [".mpeg",".mp4",".m4a",".mpg",".flv","*.mp3",".aac",".wav",".wma",".aif",".aiff",".au",".snd"];
        fileName = openFileDialog(validTypes);
but it is unclear to me how a traditional filter works with the xwidget dialogs.
The standard way of doing it, if it was a Microsoft dialog box would be:
openFileDialog.filter= ".mpeg",".mp4",".m4a",".mpg",".flv","*.mp3",".aac",".wav",".wma",".aif",".aiff",".au",".snd";
but this does not seem to work.
Instead, I am using a filter function on the returned (output) value as follows:
var validTypes = ["mpeg","mp4","m4a","mpg","flv","mp3","aac","wav","wma","aif","aiff","au","snd"];
        fileName = openFileDialog("");
        if (validate_fileupload(fileName) === true ) {
           PlayFile(fileName);
        } else {
          alert("incompatible file type");
function validate_fileupload(fileName)
    var allowed_extensions = validTypes;
    var file_extension = fileName.split('.').pop();
    for(var i = 0; i < allowed_extensions.length; i++)
        if(allowed_extensions[i]==file_extension)
            return true; // valid file extension
    return false;
This does the job but it is not the most elegant approach and so I ask: Is there a better method of adding an input filter to a file open dialog?
Documentation for xwidget is sparse as always and the inline documentation shows little as reference, so please help. It would be nice to know, then I could add it to a tutorial I am writing.
Users browsing this forum: No registered users and 69 guests
