PostPosted: September 8th, 2016, 9:11 am
Hello,
I registered to report that the download links for XWidget Portable and XLaunchpad Portable are dead.
Can anyone provide working download links for XLaunchpad Portable and XWidget Portable?
Thanks in advance.
If the developers are still reading this forum, please update the download links (and please avoid OneDrive).
PostPosted: September 8th, 2016, 10:22 am
I will send a pm to the Dev to check it..
PostPosted: September 8th, 2016, 10:37 am
@jimking
Thanks.
PostPosted: September 9th, 2016, 6:30 am
Hi Smaragdus,
Thanks for your report, I will as soon as posible to fix the links.
Or you also can make a portable version by yourself ,it is very easy,just ReName "XWidget/XLaunchpad" folder to "AppData" in your "MyDocument", and copy the AppData folder into your XWidget/XLaunchpad's folder.
Tony
smaragdus wrote:
Hello,
Thanks in advance.
