PostPosted: August 30th, 2016, 9:05 am
Image hi do nt show wiget to home sceren sorry bad english pls help me may galaxy g531h
PostPosted: August 30th, 2016, 12:54 pm
Please attach the image to the post because the image link appears broken.
Thank you
PostPosted: August 30th, 2016, 1:00 pm
http://l31i.imgup.net/tmp_24823-2783.png http://q37i.imgup.net/tmp_24823-2664.png
PostPosted: August 30th, 2016, 9:57 pm
As I can understand you use the XWidget v1.0.9
Could you please tell me the OS version?
This is really strange though because as I see from the screenshots none of the components of the widget are visible..
Is a generic problem for you or for a particular widget (?!)
Have you tried to unistall the app, delete the XWidget folder and re-install again?
The Dev working on the new version 1.1
viewtopic.php?f=18&t=6405
The app is beta and as you can understand from my last comments there, there are some things to fix before the version comes out.
Please try the new version and report.
PostPosted: August 31st, 2016, 6:03 am
Update: The new version 1.1 is ready. Please download from Playstore :)
Users browsing this forum: No registered users and 72 guests
