 Post subject: Locked out
PostPosted: May 25th, 2016, 9:55 pm
Hi all, new to the forum and need help please...
I was playing around with various features and clicked the following options...
hide right click menu for all widgets
hide widget close buttons
hide taskbar icon
and one of the widgets allowed me to hide the system taskbar
I was hoping I'd still be able to get into xwidgets somehow but I'm stuck now because the system taskbar is gone and I can't right-click the widgets (even if I press 'CTRL').
Is there a global (or widget) xwidget config file that I can edit please, as I can still launch windows explorer using the task manager (CTRL+ALT+DELETE)
Thank you.
 Post subject: Re: Locked out
PostPosted: May 25th, 2016, 10:22 pm
Hello veganpete. Holding down ctrl and press right click on a widget will appear the right click menu. You can navigate through settings from there. Enable again the taskbar and restart your pc
