 Post subject: Win 7 - show desktop
PostPosted: February 3rd, 2016, 5:43 am
Hi. Windows 7 - desktop button in the lower right corner, xwidgets no hide. Help thx.
 Post subject: Re: Win 7 - show desktop
PostPosted: February 3rd, 2016, 7:55 am
Hi sacrifice. What exacly you want to do..? I don't understand because there is no connection between the win7 desktop button and hide widgets!
There is a different action for this. The desktop button is irrelevant..
PostPosted: February 3rd, 2016, 8:53 am
Another "Hide Desktop Widgets" ok, why not desktop button? rainmeter, rainlendar... desktop button works and widgets hiding.
PostPosted: February 3rd, 2016, 10:20 am
I can tell you how XWidget works and as I know this can be done using a hot-key (through XW icon tray->Options-> Hotkeys)
I don't know if Tony will add it on v2.0 but for now is not supported..
Users browsing this forum: No registered users and 72 guests
