 Post subject: Installing new widgets
PostPosted: April 27th, 2015, 9:58 pm
Hi
Im downloading new widgets but I cannot get them to install. Someone please help.
They download as a xwp file but xwidget doesn't want to know anything about it, doesn't automatically open or anything
PostPosted: April 27th, 2015, 11:06 pm
and xwidget is running in your system tray?
Did you try to right click and choose open with and find the exe file in Programs for Xwidget, maybe that will associate it
Cheers, Pete
PostPosted: April 28th, 2015, 12:02 am
When you download a new widget (.xwp file), Windows recognizes it? Or you have an empty icon?
If this happens try to re-install XWidget (overwrite). Also fix manually the "open with" menu for such files selecting "always with" and XWidget program. There is a corruption of your registry.
Try these and tell me if works. If still doesn't work there are a couple of things that you can do..
PostPosted: April 28th, 2015, 2:11 am
Have tried both and just tells me xwidget is already running and does nothing to install the new widget I have downloaded.
No windows didnt recognise it so had to associate it manually to no avail.
I am running windows 8.1 64bit if that helps
PostPosted: April 28th, 2015, 2:22 am
I have time ago the same problem but as I saw was a registry problem. Happens..
Since windows dont recognize it, do as @djpete says. Right click and choose open with and find the exe file in Programs for Xwidget, to associate it.
If this doesn't work use this little great program that puts manually programs to open with window/list and find the xwidget.exe.
And do the same procedure..
Also I give you this great prem (mod) registry program to check and fix all the pc registry errors!
I tried both and all works perfectly after that..! :)
SysTweak.Regclean.Pro.7.2.72.170.rar [4.32 MiB]
Downloaded 1146 times
OpenWithAdd_1.2.zip [32.57 KiB]
Downloaded 1015 times
PostPosted: April 28th, 2015, 2:23 am
Maybe try restarting xwidget and trying another widget
Cheers, Pete
PostPosted: April 28th, 2015, 2:29 am
Restarting a program there is no effect for such matters. It's all about Windows and registry and how the files are recognized from the system.. Re-installing yes, and not always..
PostPosted: April 28th, 2015, 2:31 am
Have also tried another widget and same results. So manually association it with the main xwidget exe isnt causing problms then?
tring reg program now
PostPosted: April 28th, 2015, 2:36 am
Of course not! With this way you only fix windows/registry corruption. I use pcs for years, trust me..Go ahead :)
I strongly suggest you to use AND the registry program that I have sent you.. Because even you fixed the open with menu, some things in the registry maybe will cause the same things after a while..
It's on top of the list of the regisrty cleaners 2015:
http://registry-cleaners-software-revie ... views.com/
PostPosted: April 28th, 2015, 2:52 am
Have done what you have asked with no success. Keeps telling me xwidget is already running.
Have restarted machine just to make sure.
Tell you what though that great little program has speed things up on my machine!
PostPosted: April 28th, 2015, 3:07 am
Close completely XWidget from the icon tray.
If all work properly you have to see this for the XWidgets/files:
If not you see this:
I modify on purpose a widget to show: (my windows 7 32x are in greek but the procudure is the same)
1) Press "Open" and select the second option to open the installed programs association window.
Use the " OpenWithAdd" program that I sent you here, you will see XWidget in the list:
Be sure that the option "Always with" is ENABLE!
2) Select OK and check.
3) Run a regisrty scan with the program that I attached you here (be sure that all the categories are selected from the "Settings") AND the "Defrag Registry".
The pc will restart on its own and check. Requires a little time, don't worry.
All I did were these steps and I have no problems any more.
PostPosted: April 28th, 2015, 3:18 am
I have just hit success. An update was requested, updated and boom everything works. Cheers everyone for your help but seems like magic everything is working as it should!
Cheers jimking for that reg program my machine is actually running smoother, seems alot better from the first day I got it, great help
PostPosted: April 28th, 2015, 3:24 am
I'm glad that all work now! :)
Remember that procedures like clean/fix the registry and defragment once a while are always necessary if you want to keep your pc as new as possible without crashes or surprises.. ;)
Windows 8 /8.1 is new and obviously microsoft never do the things as they should. So they need updates to fix the stupid errors..
For me win7 remains the best. Win8 is a pain in the a... to find things! :lol:
Cheers
