PostPosted: April 6th, 2015, 1:41 am
Hi everybody,
I installed "VOLUME HD 2" on my pc.
And I activated "Mouse Through" in the right clic menu options, and since then, I can't go back to the menu.
Because the widget is like hidden from the mouse of course !...
How can I do to undo this ?
Thanks.
PostPosted: April 6th, 2015, 1:47 am
Ok everybody I'm very sorry (and very pleased in the same time) because I just found the solution by myself...
Just press the "Ctrl" key while you right click on the widget and you will then have the entire menu access again.
Good job then and end of the post.
Thank you.
PostPosted: April 6th, 2015, 3:24 am
All ok then! :)
